Api session items functions
Revision as of 12:08, 29 May 2026 by Frank@tygron.nl (talk | contribs)
Api session items Function Endpoint: /api/session/items/functions/
Default Query:
https://engine.tygron.com/api/session/items/functions/?f=JSON&token=API_TOKEN
Example Response:
  "attributes" : {
    "DISTURBANCE_DISTANCE_M" : [ 0.0 ],
    "OTHER_CONSTRUCTION_COST_M2" : [ 4000.0 ],
    "BOWEN_RATIO" : [ 3.0 ],
    "NUM_PEDESTRIANS" : [ 0.0 ],
    "OTHER_SELL_PRICE_M2" : [ 5000.0 ],
    "OTHER_HEAT_FLOW_M2_CHANGE_PER_YEAR" : [ 0.0 ],
    "SLANTING_ROOF_HEIGHT" : [ 0.0 ],
    "ZONING_PERMIT_REQUIRED" : [ 0.0 ],
    "NUM_CARS" : [ 0.0 ],
    "GROUND_COLOR" : [ -4808597.0 ],
    "ALIGN_ELEVATION" : [ 2.0 ],
    "NUM_BICYCLES" : [ 0.0 ],
    "OTHER_PARKING_LOTS_PER_M2" : [ 0.0 ],
    "ROOF_COLOR" : [ -4808597.0 ],
    "SEWERED" : [ 0.0 ],
    "OTHER_HEAT_POWER_TO_FLOW_MULTIPLIER" : [ 0.0 ],
    "DRAINAGE" : [ 0.0 ],
    "JAM_FACTOR_CARS" : [ 0.0 ],
    "TRAFFIC_LANES" : [ 0.0 ],
    "LIVABILITY_EFFECT" : [ 0.0 ],
    "WATER_MANNING" : [ 0.025 ],
    "WATER_STORAGE_M2" : [ 0.0 ],
    "MONUMENTAL" : [ 0.0 ],
    "NUM_TRUCKS" : [ 0.0 ],
    "OTHER_BUYOUT_COST_M2" : [ 4000.0 ],
    "NUM_AIRPLANES" : [ 0.0 ],
    "GROUND_INFILTRATION_MD" : [ 0.0 ],
    "NUM_BUSES" : [ 0.0 ],
    "OTHER_UNIT_SIZE_M2" : [ 1.0 ],
    "NUM_VANS" : [ 0.0 ],
    "SOLID" : [ 0.0 ],
    "JAM_FACTOR_VANS" : [ 0.0 ],
    "HEIGHT_OFFSET_M" : [ 0.0 ],
    "WATER_TRANSPIRATION_FACTOR" : [ 0.0 ],
    "CRITICAL_INFRASTRUCTURE" : [ 1.0 ],
    "ROOT_DEPTH_M" : [ 0.0 ],
    "TRAFFIC_NOISE_SIGMA" : [ 0.0 ],
    "TRAFFIC_SPEED" : [ 0.0 ],
    "HEAT_EFFECT" : [ -6.0 ],
    "VEGETATION_FRACTION" : [ 0.0 ],
    "OTHER_HEAT_FLOW_M2_START_YEAR" : [ 0.0 ],
    "OTHER_DEMOLISH_COST_M2" : [ 250.0 ],
    "OTHER_HEAT_FLOW_M2_START_VALUE" : [ 0.0 ],
    "WATER_MICRORELIEF_M" : [ 0.0 ],
    "NUM_SHIPS" : [ 0.0 ],
    "MAX_FLOORS" : [ 1.0 ],
    "OTHER_CATEGORY_WEIGHT" : [ 1.0 ],
    "JAM_FACTOR_TRUCKS" : [ 0.0 ],
    "NUM_TRAINS" : [ 0.0 ],
    "OTHER_PARKING_LOTS_DEMAND_PER_M2" : [ 0.0 ],
    "DISTANCE_ZONE_M" : [ 0.0 ],
    "TRAFFIC_NOISE_TAU" : [ 0.0 ],
    "FOLIAGE_CROWN_FACTOR" : [ 0.0 ],
    "BASEMENT_COLOR" : [ -1.1776948E7 ],
    "DEFAULT_FLOORS" : [ 1.0 ],
    "EXTRA_COLOR" : [ -4808597.0 ],
    "SOLAR_PANELS" : [ 0.0 ],
    "TOP_COLOR" : [ -4808597.0 ],
    "JAM_FACTOR_BUSES" : [ 0.0 ],
    "NUM_TRAMS" : [ 0.0 ],
    "BASEMENT_HEIGHT_M" : [ 0.0 ],
    "PIPES_PERMITTED" : [ 0.0 ],
    "FLOOR_HEIGHT_M" : [ 0.0 ],
    "TERRAIN_MIX" : [ 0.8 ],
    "MIN_FLOORS" : [ 1.0 ],
    "SAFETY_DISTANCE_M" : [ 0.0 ]
  "categories" : [ "OTHER" ],
  "constructionPeriods" : [ ],
  "decals" : null,
  "defaults" : [ ],
  "description" : "",
  "dimension" : -1,
  "id" : 0,
  "imageName" : "braak.png",
  "modelSetID" : 1,
  "name" : "Vacant Lot",
  "placementType" : "LAND",
  "regions" : [ "NORTHWESTERN_EUROPE" ],
  "textures" : {
    "ROOF" : "sand"
  "version" : 22
  "attributes" : {
    "SLANTING_ROOF_HEIGHT" : [ 2.2 ],
    "ZONING_PERMIT_REQUIRED" : [ 1.0 ],
    "GROUND_COLOR" : [ -1.0197916E7 ],
    "ALIGN_ELEVATION" : [ 0.0 ],
    "ROOF_COLOR" : [ -1.0599374E7 ],
    "SEWERED" : [ 1.0 ],
    "LIVABILITY_EFFECT" : [ -5.0 ],
    "WATER_MANNING" : [ 0.013 ],
    "SOCIAL_UNIT_SIZE_M2" : [ 80.0 ],
    "SOCIAL_PARKING_LOTS_PER_M2" : [ 0.0 ],
    "SOLID" : [ 1.0 ],
    "SOCIAL_CONSTRUCTION_COST_M2" : [ 2000.0 ],
    "HEAT_EFFECT" : [ 5.0 ],
    "SOCIAL_SELL_PRICE_M2" : [ 3000.0 ],
    "SOCIAL_CATEGORY_WEIGHT" : [ 1.0 ],
    "SOCIAL_HEAT_FLOW_M2_CHANGE_PER_YEAR" : [ -1.26E-4 ],
    "MAX_FLOORS" : [ 3.0 ],
    "SOCIAL_HEAT_FLOW_M2_START_VALUE" : [ -0.315264 ],
    "SOCIAL_BUYOUT_COST_M2" : [ 2400.0 ],
    "SOCIAL_PARKING_LOTS_DEMAND_PER_M2" : [ 0.029999999329447746 ],
    "DEFAULT_FLOORS" : [ 2.0 ],
    "EXTRA_COLOR" : [ -1.0197916E7 ],
    "SOCIAL_HEAT_POWER_TO_FLOW_MULTIPLIER" : [ 4.86 ],
    "TOP_COLOR" : [ -1.0197916E7 ],
    "SOCIAL_HEAT_FLOW_M2_START_YEAR" : [ 1900.0 ],
    "BASEMENT_HEIGHT_M" : [ 2.0 ],
    "FLOOR_HEIGHT_M" : [ 3.2 ],
    "SOCIAL_DEMOLISH_COST_M2" : [ 150.0 ],
  "categories" : [ "SOCIAL" ],
  "constructionPeriods" : [ "POST_WAR" ],
  "decals" : {
    "EXTRA" : [ 10.0, 0.0, 1.0, 1.98, 2.0, 0.84, 0.0, 2.7, 1.98, 3.7, 0.84, 0.0, 8.2, 1.98, 9.2, 0.84 ],
    "TOP" : [ 10.0, 0.0, 1.0, 1.74, 2.0, 0.6, 0.0, 4.5, 1.74, 5.5, 0.6, 0.0, 6.2, 1.74, 7.2, 0.6 ],
    "ROOF" : [ ],
    "GROUND" : [ 10.0, 1.0, 1.0, 1.98, 2.4, 0.0, 0.0, 3.3, 1.98, 4.3, 0.81, 0.0, 6.8, 1.98, 7.8, 0.81, 0.0, 8.5, 1.98, 9.5, 0.81 ]
  "defaults" : [ ],
  "description" : "",
  "dimension" : -1,
  "id" : 1,
  "imageName" : "huisje7.png",
  "modelSetID" : 2,
  "name" : "Mid-Century affordable housing",
  "textures" : {
    "EXTRA" : "bricks",
    "TOP" : "bricks",
    "ROOF" : "pane",
    "GROUND" : "bricks"
  "version" : 23
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/functions/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/functions/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/functions/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/functions/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/functions/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/functions/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/functions/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/functions/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/functions/?f=ZIPSMILE&token=API_TOKEN
Api Model BaseFunction
API Model description of BaseFunction
Name Type Description
attributes Map<String,double[]>
categories Category[]
constructionPeriods ConstructionPeriod[]
decals Map<FaceType,float[]>
defaults Type[]
description String
dimension int
id int
imageName String
modelSetID int Model Set ID
name String
placementType PlacementType
regions Region[]
textures Map<FaceType,String>
version int
Api Model Category
API Enumeration description of Category
Name Description
SOCIAL
NORMAL
LUXE
ROAD
PAVED_AREA
EDUCATION
HEALTHCARE
PARK
NATURE
INDUSTRY
OFFICES
OTHER
SENIOR
UNDERGROUND
SHOPPING
AGRICULTURE
LEISURE
STUDENT
GARDEN
INTERSECTION
BRIDGE
Api Model ConstructionPeriod
API Enumeration description of ConstructionPeriod
Name Description
ANCIENT
CLASSIC
PRE_WAR
POST_WAR
CONTEMPORARY
FUTURISTIC
Api Model DuplicateFunction
API Model description of DuplicateFunction
id int
orginalFunctionID int Function ID
version int
Api Model FaceType
API Enumeration description of FaceType
Name Description
BASEMENT
GROUND
EXTRA
TOP
ROOF
Api Model Function
API Model description of Function
id int
version int
Api Model PlacementType
API Enumeration description of PlacementType
Name Description
WATER
LAND
HYBRID
Api Model Region
API Enumeration description of Region
Name Description
NORTH_AMERICA
NORTHWESTERN_EUROPE
ASIA
AFRICA
OTHER
Api Model Type (Stakeholder)
API Enumeration description of Type
Name Description
CIVILIAN
COMPANY
EDUCATION
EXPERT
FARMER
HEALTHCARE
HOUSING_CORPORATION
MUNICIPALITY
MEDIA
PROJECT_DEVELOPER
UTILITY_CORPORATION
WATER_AUTHORITY
OTHER_AUTHORITY
OTHER
