Api session items zipcodes
Api session items Zip Codes Endpoint: /api/session/items/Zip Codes/
Default Query:
https://engine.tygron.com/api/session/items/zipcodes/?f=JSON&token=API_TOKENExample Response:
[ ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/zipcodes/?version=100&token=API_TOKENPseudo-Mercator:
https://engine.tygron.com/api/session/items/zipcodes/?crs=3857&token=API_TOKENDegrees:
https://engine.tygron.com/api/session/items/zipcodes/?crs=4326&token=API_TOKENAmersfoort / RD New:
https://engine.tygron.com/api/session/items/zipcodes/?crs=28992&token=API_TOKENLocal Coordinates:
https://engine.tygron.com/api/session/items/zipcodes/?crs=LOCAL&token=API_TOKENbbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/zipcodes/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKENFOO:
https://engine.tygron.com/api/session/items/zip_codes-foo/?crs=3857&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/zipcodes/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/zipcodes/size/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/zipcodes/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/zipcodes/?f=JSON&token=API_TOKENGEOJSON:
https://engine.tygron.com/api/session/items/zipcodes/?f=GEOJSON&token=API_TOKENGPKG:
https://engine.tygron.com/api/session/items/zipcodes/?f=GPKG&token=API_TOKENDXF:
https://engine.tygron.com/api/session/items/zipcodes/?f=DXF&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/zipcodes/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/zipcodes/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/zipcodes/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/zipcodes/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/zipcodes/?f=ZIPSMILE&token=API_TOKENApi Model GeometryCollection
API Model description of GeometryCollection
| Name | Type | Description |
Api Model MultiPolygon
API Model description of MultiPolygon
| type | String | MultiPolygon |
| coordinates | double[][][][] | array of polygons; polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z] |
Api Model TColor
API Model description of TColor
Api Model ZipCode
API Model description of ZipCode
| color | TColor | |
| id | int | |
| name | String | |
| polygons | MultiPolygon | |
| sourceIDs | int[] | Source ID |
| version | int |
