Api session items triggers
Api session items Trigger Endpoints.
Edit items with event: editortrigger.
Default Query:
https://engine.tygron.com/api/session/items/triggers/?f=JSON&token=API_TOKENExample Response:
"active" : true,
"calcTimeMS" : 136,
"id" : 1,
"method" : "GET",
"name" : "Before",
"timeoutMS" : 10000,
"timing" : "BEFORE",
"type" : "TQL",
"url" : "https://development.tygron.com/api/session/hello",
"version" : 1,
"warnings" : ""
"active" : true,
"calcTimeMS" : 0,
"id" : 2,
"method" : "GET",
"name" : "After",
"timing" : "AFTER",
"type" : "TQL",
"url" : "https://api.powerbi.com/v1.0/myorg/groups/%7BgroupId%7D/datasets/%7BdatasetId%7D/refreshes",
"version" : 2,
"warnings" : "Warning:"
} ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/triggers/?version=100&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/triggers/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/triggers/size/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/triggers/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/triggers/?f=JSON&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/triggers/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/triggers/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/triggers/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/triggers/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/triggers/?f=ZIPSMILE&token=API_TOKENApi Model Method
API Enumeration description of Method
| Name | Description |
| GET | |
| POST |
Api Model Timing
API Enumeration description of Timing
| BEFORE | |
| AFTER |
Api Model Trigger
API Model description of Trigger
| Name | Type | Description |
| active | boolean | |
| calcTimeMS | long | |
| id | int | |
| method | Method | |
| name | String | |
| timeoutMS | int | |
| timing | Timing | |
| type | Type | |
| url | String | |
| version | int | |
| warnings | String |
Api Model Type (Trigger)
API Enumeration description of Type
| TQL | |
| EVENT |
