Api session event editor update
Revision as of 12:22, 19 May 2026 by Maxim@tygron.com (talk | contribs)
API Endpoint: api/session/event/editor/update/
Description: Calculate all active Overlay, Indicator, Panel and Trigger and wait for the update. Note: for long-running calculations use: set_scheduled_update/ to schedule an update.
0 OPTIONAL (true, false) Reset all X-Queries (optional)
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editor/update/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''
JavaScript example POST:
 body: ''
fetch("https://engine.tygron.com/api/session/event/editor/update/", options)
