Api session event editor building add geometry
Revision as of 11:26, 19 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorbuilding/add_geometry/
Description: Add a custom Building geometry
0 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Building ID
1 REQUIRED (CUSTOM_GEOMETRIE Integer ID or multiple values in array [1, 2, 3]) Custom Geometry ID
2 REQUIRED (boolean or multiple values in array [a, b, c]) Primary Building for geometry
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorbuilding/add_geometry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/add_geometry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ true, false, true ] ]'
JavaScript example POST:
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/add_geometry/", options)
