Api session event editor update with id
Revision as of 11:25, 19 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editor/update_with_id/
Description: Waits for update of all active Overlay, Indicator, Panel and Trigger with unique ID. Note: for long-running updates use: set_scheduled_update/ to schedule an update.
0 REQUIRED (true, false) Reset all X-Queries true or false
1 REQUIRED (Integer number) Unique Update ID to prevent multiple updates
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editor/update_with_id/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ true, 82 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editor/update_with_id/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ true, 13 ]'
JavaScript example POST:
 body: '[ true, 82 ]'
fetch("https://engine.tygron.com/api/session/event/editor/update_with_id/", options)
