Api session event editor zoning set permitter
API Endpoint: api/session/event/editorzoning/set_permitter/
Description: Set Permitter
| 0 | REQUIRED | (ZONE Integer ID) | Zone | |
| 1 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/session/event/editorzoning/set_permitter/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorzoning/set_permitter/", options)
