Api session event editor stakeholder reset web token
Revision as of 08:18, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorstakeholder/reset_web_token/
Description: Reset Web Token
0 REQUIRED (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) Stakeholder
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/reset_web_token/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/reset_web_token/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorstakeholder/reset_web_token/", options)
