Api session event editor projectasset add
API Endpoint: api/session/event/editorprojectasset/add/
Description: Upload a new image as a Project asset.
| 0 | REQUIRED | (String) | Directory to upload to | |
| 1 | REQUIRED | (String) | Filename. This should a simple file name, including extension | |
| 2 | REQUIRED | (byte or multiple values in array [a, b, c]) | File data |
| 200 | Integer (Project Asset ID) |
curl 'https://engine.tygron.com/api/session/event/editorprojectasset/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Directory to upload to", "Filename. This should a simple file name, including extension", 1 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorprojectasset/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Directory to upload to", "Filename. This should a simple file name, including extension", [ 1, 2, 3 ] ]'JavaScript example POST:
body: '[ "Directory to upload to", "Filename. This should a simple file name, including extension", 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorprojectasset/add/", options)
