Api session event editor plot set name
API Endpoint: api/session/event/editorplot/set_name/
Description: Set new name of existing Plot
| 0 | REQUIRED | (PLOT Integer ID or multiple values in array [1, 2, 3]) | Plot | |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorplot/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text 1" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorplot/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]'JavaScript example POST:
body: '[ 1, "Text 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorplot/set_name/", options)
