Api session event editor overlay set tensor normalized
API Endpoint: api/session/event/editoroverlay/set_tensor_normalized/
Description: Set whether an input tensor of an Inference Overlay should be normalized when provided to a Neural Network.
| 0 | REQUIRED | (OVERLAY Integer ID) | Inference Overlay ID | |
| 1 | REQUIRED | (Integer number) | Tensor Link ID | |
| 2 | REQUIRED | (true, false) | Normalize | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_tensor_normalized/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, false ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_tensor_normalized/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'JavaScript example POST:
body: '[ 1, 1, false ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_tensor_normalized/", options)
