Api session event editor overlay set service crs
API Endpoint: api/session/event/editoroverlay/set_service_crs/
Description: Set the prefered CRS for the Service Source of a specified Service Overlay.
| 0 | REQUIRED | (OVERLAY Integer ID or multiple values in array [1, 2, 3]) | Service Overlay ID | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | CRS name |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_service_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "CRS name 1" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_service_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "CRS name 1", "CRS name 2", "CRS name 3" ] ]'JavaScript example POST:
body: '[ 1, "CRS name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_service_crs/", options)
