Api session event editor overlay set net overlay
Revision as of 08:16, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_net_overlay/
Description: Set the visualization style for a specified network Overlay.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a network Overlay)
1 REQUIRED (Enumeration) Net Type ELECTRICITY, GAS, HEAT, INTERNET or SEWER
2 REQUIRED (true, false) Whether to show the network (false means no lines will be visualized) true or false
3 REQUIRED (true, false) Whether only active connections should be visualized (false means both active and inactive connections are visualized) true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_net_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "ELECTRICITY", false, false ]'
JavaScript example POST:
 body: '[ 1, "ELECTRICITY", false, false ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_net_overlay/", options)
