Api session event editor overlay set image
Revision as of 08:16, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_image/
Description: Change the icon displayed in the navigation window by the Overlay. Only existing Overlay Project Asset are allowed.
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay ID
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Project asset name, omitting the directory
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Project asset name, omitting the directory 1" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Project asset name, omitting the directory 1", "Project asset name, omitting the directory 2", "Project asset name, omitting the directory 3" ] ]'
JavaScript example POST:
 body: '[ 1, "Project asset name, omitting the directory 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_image/", options)
