Api session event editor overlay set custom legend
Revision as of 08:16, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_custom_legend/
Description: Set whether the specified Overlay has a custom legend. If the specified Overlay is reverted to use a default Overlay, any custom legend information for the Overlay is removed.
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 REQUIRED (true, false) Has a custom legend (false sets the Overlay to use the default legend) true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_custom_legend/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
JavaScript example POST:
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_custom_legend/", options)
