Api session event editor neighborhood remove polygons
API Endpoint: api/session/event/editorneighborhood/remove_polygons/
Description: Remove polygons from existing Neighborhood
| 0 | REQUIRED | (NEIGHBORHOOD Integer ID) | Neighborhood | |
| 1 | REQUIRED | (MultiPolygon with crs: EPSG:3857) | MultiPolygon |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorneighborhood/remove_polygons/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
'JavaScript example POST:
body: '[ 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]} ]'
fetch("https://engine.tygron.com/api/session/event/editorneighborhood/remove_polygons/?crs=3857", options)
