Api session event editor measure import building measure
Revision as of 08:16, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editormeasure/import_building_measure/
Description: Use IMPORT_Building instead, same event with option to set existing Measure.
