Api session event editor measure set levee angle
API Endpoint: api/session/event/editormeasure/set_levee_angle/
Description: Set the angle of Levee Spatial of a Measure.
| 0 | REQUIRED | (MEASURE Integer ID) | Measure IDs | |
| 1 | REQUIRED | (Integer number) | Levee Spatial ID | |
| 2 | OPTIONAL | (Floating point number) | Angle |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_levee_angle/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "" ]'JavaScript example POST:
body: '[ 1, 1, "" ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_levee_angle/", options)
