Api session event editor measure import grids
Revision as of 08:15, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editormeasure/import_grids/
Description: Import Measure Grid Collection
0 REQUIRED (GeometryCollection with crs: EPSG:3857) Collection of Grid Geometries where the Grid will be applied
1 REQUIRED (TERRAIN_TYPE Integer ID or multiple values in array [1, 2, 3]) Terrain Type IDs
2 REQUIRED (Integer or multiple values in array [a, b, c]) Grid ID arrays
3 OPTIONAL (MEASURE Integer ID) Set for existing Measure ID (optional)
4 OPTIONAL (Floating point number) Buffer for Points and Lines to make Polygons (optional)
5 OPTIONAL (SOURCE Integer ID) Source (optional)
200 Integer (Measure ID)
curl 'https://engine.tygron.com/api/session/event/editormeasure/import_grids/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
 "type" : "GeometryCollection",
 "geometries" : [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, 1, [ 1, 2 ], "", "", "" ]
Curl example multi item POST:
 "geometries" : [ {
 "coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
}, [ 1, 2, 3 ], [ [ 1, 2 ], [ 3, 4 ], [ 5, 6 ] ], "", "", "" ]
JavaScript example POST:
 body: '[ { "type" : "GeometryCollection", "geometries" : [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ] } ]}, 1, [ 1, 2 ], "", "", "" ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/import_grids/?crs=3857", options)
