Api session event editor geooption reset
Revision as of 08:14, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorgeooption/reset/
Description: Reset
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeooption/reset/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ ]'
JavaScript example POST:
 body: '[ ]'
fetch("https://engine.tygron.com/api/session/event/editorgeooption/reset/", options)
