Api session event editor cinematic set keypoint paused
API Endpoint: api/session/event/editorcinematic/set_keypoint_paused/
Description: Set Keypoint Paused
| 0 | REQUIRED | (CINEMATIC_DATA Integer ID) | Cinematic | |
| 1 | REQUIRED | (Integer number) | Integer | |
| 2 | REQUIRED | (true, false) | Boolean | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_paused/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, false ]'JavaScript example POST:
body: '[ 1, 1, false ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_paused/", options)
