Api session event editor building multi select
API Endpoint: api/session/event/editorbuilding/multi_select/
Description: Multi Select
| 0 | REQUIRED | (FUNCTION Integer ID) | Function | |
| 1 | REQUIRED | (Integer number) | Integer | |
| 2 | REQUIRED | (true, false) | Boolean | true or false |
| 3 | REQUIRED | (BUILDING Integer ID or multiple values in array [1, 2, 3]) | Building |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorbuilding/multi_select/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true, 1 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/multi_select/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true, [ 1, 2, 3 ] ]'JavaScript example POST:
body: '[ 1, 1, true, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/multi_select/", options)
