Api session event editor attributeaction add
Revision as of 08:14, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorattributeaction/add/
Description: Add new Attribute Action
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorattributeaction/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ ]'
JavaScript example POST:
 body: '[ ]'
fetch("https://engine.tygron.com/api/session/event/editorattributeaction/add/", options)
