Api session event editor area remove group
Revision as of 08:14, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorarea/remove_group/
Description: Remove Group
0 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/remove_group/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"Text 1"'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/remove_group/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text 1", "Text 2", "Text 3" ]'
JavaScript example POST:
 body: '"Text 1"'
fetch("https://engine.tygron.com/api/session/event/editorarea/remove_group/", options)
