Scenario
What are Levels?
A Level is a relative position or rank on a scale.
How do Levels relate to the Tygron Engine
A project in the Tygron Engine can be set up as a Timeline based project. A session of such a project will progress along a time line, with the intention to see the impact of actions and measures on the indicators over time.
For different reasons it is possible to divide this timeline in two or more levels. Reasons to do so can be (but are not limited to):
  • to provide the session participants a learning curve to get used to the Tygron Engine interaction
Create a first level as tutorial where a stakeholder can only perform a limited number of actions and measures, maybe even in a secluded area in the 3D World, in order to get acquainted with the interaction with the project in the Tygron Engine, without affecting the outcome of the session as a whole.
  • to gradually make the project interaction more complex, to match the issue in real life more closely
Add more complex actions, measures and indicators to let session participants gradually experience the complexity of the spatial planning issue(s) at hand. This can be combined with the above mentioned reason of course.
  • to jump in time to a future scenario
Each level can start with an event that reflects future scenarios, such as floodings that only occur once every fifty and every one hundred years, or the sea level rise over time for instance.
  • to provide pause moments during a session
Sessions often take place during business hours, taking up a whole morning, afternoon or even the whole day. By implementing levels the session flow can be interrupted to incorporate pause moments for reflection and refreshments.
Adding, duplicating and removing Levels in a project
Template:Editor ribbon
Adding a Level
Add new level - drop down menu
Add new level - left panel
How to add levels to a project:
  1. Select Storyline → Levels
  2. Select Add new Level from the drop down menu
  3. Or select Add on the bottom of the left panel
Duplicating a Level
Select level to duplicate on left panel
Duplicate selected level
When levels are used to add complexity or to provide a tutorial, it can be very convenient to be able to duplicate a previous level. This avoids having to create and assign all previous actions, measures and indicators again for each consecutive level. In stead, only the added complexity needs to be put in the duplicated level.
How to duplicate levels in a project:
  2. Select the level to be duplicated on the left panel
  3. Select Duplicate on the bottom of the left panel
Removing a Level from a project
Changing the properties of a Level
Level
Name
Description
Event Bundles
Server Events fired when chosen
Measures
Stakeholders
Provided Budget
Start with Cinematic
Active Action Menus
Playable Zones
