Api session event editor actionmenu remove actions
API Endpoint: editoractionmenu/remove_actions.
Description: Remove Actions
0 REQUIRED (ACTION_MENU Integer ID or multiple values in array [1, 2, 3]) Action Menu
1 REQUIRED (MapLink or multiple values in array [a, b, c]) Maplink[]
2 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoractionmenu/remove_actions/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SETTINGS", 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoractionmenu/remove_actions/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "SETTINGS", "ACTION_MENUS", "ADDRESSES" ], [ 1, 2, 3 ] ]'
JavaScript example POST:
 body: '[ 1, "SETTINGS", 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoractionmenu/remove_actions/", options)
