How to add a Terrain Spatial to a Measure
Revision as of 11:22, 29 April 2026 by Frank@tygron.nl (talk | contribs)
Terrain Spatials can be used to flatten land, remove Buildings, adjust terrain height and Terrain Type.
How to add a Terrain Spatial to a Measure:
  1. Select the Future Design tab in the ribbon bar.
  2. Select or add a new Measure
  3. With the Measure selected, click on the Add Terrain button
  4. With the Terrain Spatial added and selected
  5. Select the WATER 1 (default) entry
  6. In the Detail Panel, select FLATTEN as type from the drop down menu
  7. Use brush panel to draw Outer Area, and apply
  8. Select the Measure and click on Activate Measure to inspect its application
