Api session items stakeholders
Revision as of 14:14, 24 April 2026 by Frank@tygron.nl (talk | contribs)
Api session items Stakeholder Endpoints.
Edit items with event: editorstakeholder.
Default Query:
https://engine.tygron.com/api/session/items/stakeholders/?f=JSON&token=API_TOKEN
Example Response:
  "active" : true,
  "client" : null,
  "color" : {
    "argb" : -3355444
  "id" : 0,
  "imageName" : "municipality.png",
  "imageVersion" : 0,
  "lastSelected" : 1774446787083,
  "name" : "Municipality Arnhem",
  "shortName" : "Arnhem",
  "startBudget" : 0.0,
  "startBudgets" : {
    "0" : 1000000.0
  "startCinematics" : {
    "0" : 0
  "startPoint" : null,
  "type" : "MUNICIPALITY",
  "version" : 6,
  "webToken" : "RHVXnEVpNcbfEBNQKWmwxAXQ"
  "active" : true,
  "client" : null,
  "color" : {
    "argb" : -360334
  "id" : 1,
  "imageName" : "civilian.png",
  "imageVersion" : 0,
  "lastSelected" : 1741957674390,
  "name" : "Inhabitants",
  "shortName" : "Inhabitants",
  "startBudgets" : {
    "0" : 0.0
    "0" : 0
  "type" : "CIVILIAN",
  "version" : 5,
  "webToken" : "NZPc6qRkfTYYjmDPjywXADjj"
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/stakeholders/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/stakeholders/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/stakeholders/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/stakeholders/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/stakeholders/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/stakeholders/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/stakeholders/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/stakeholders/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/stakeholders/?f=ZIPSMILE&token=API_TOKEN
Api Model Point
API Model description of Point
Name Type Description
Api Model Stakeholder
API Model description of Stakeholder
active boolean
client ClientData
color TColor
id int
imageName String
imageVersion int
lastSelected long
name String
shortName String
startBudget double
startBudgets Map<int,double>
startCinematics Map<int,int>
startPoint Point
type Type
version int
webToken String
Api Model TColor
API Model description of TColor
Api Model Type (Stakeholder)
API Enumeration description of Type
Name Description
CIVILIAN
COMPANY
EDUCATION
EXPERT
FARMER
HEALTHCARE
HOUSING_CORPORATION
MUNICIPALITY
MEDIA
PROJECT_DEVELOPER
UTILITY_CORPORATION
WATER_AUTHORITY
OTHER_AUTHORITY
OTHER
