Api session items attributeactions
Revision as of 14:14, 24 April 2026 by Frank@tygron.nl (talk | contribs)
Api session items Attribute Actions Endpoints.
Edit items with event: editorattributeaction.
Default Query:
https://engine.tygron.com/api/session/items/attributeactions/?f=JSON&token=API_TOKEN
Example Response:
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/attributeactions/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/attributeactions/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/attributeactions/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/attributeactions/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/attributeactions/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/attributeactions/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/attributeactions/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/attributeactions/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/attributeactions/?f=ZIPSMILE&token=API_TOKEN
Api Model AttributeAction
API Model description of AttributeAction
Name Type Description
attributes Map<String,double[]>
description String
fixedValue boolean
id int
imageName String
imageVersion int
maquetteOverride Map<String,double[]>
name String
version int
