Api session event editor chatchannel append attribute
Revision as of 08:47, 24 April 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: editorchatchannel/append_attribute. Description: Appended to existing Chat Channel attribute value {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(CHAT_CHANNEL Integer ID or multiple values in array [1, 2, 3]) |Chat Channel | |- |1 |REQUIRED |(String) |Attribute Name | |- |2 |REQUIRED |(Floating point number or multiple values in array [1.0, 2.0, 3.0]) |Attribute Values appended to existing values | |- |3 |OPTIONAL...")
0 REQUIRED (CHAT_CHANNEL Integer ID or multiple values in array [1, 2, 3]) Chat Channel
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Attribute Values appended to existing values
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/append_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name", 1.0, "" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/append_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], "Attribute Name", [ 1.0, 2.0, 3.0 ], "" ]'
JavaScript example POST:
 body: '[ 1, "Attribute Name", 1.0, "" ]'
fetch("https://engine.tygron.com/api/session/event/editorchatchannel/append_attribute/", options)
