Api session event editor measure import building measure
Revision as of 14:59, 20 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editormeasure/import_building_measure.
Description: Use IMPORT_Building instead, same event with option to set existing Measure.
