Api session event editor chatmessage add
API Endpoint: editorchatmessage/add.
Description: Add a new Chat Message
| 0 | REQUIRED | (CHAT_CHANNEL Integer ID) | Channel ID | |
| 1 | REQUIRED | (String) | Message content |
| 200 | Integer (Return ID of the future reponse message (note: not my own added message)) |
curl 'https://engine.tygron.com/api/session/event/editorchatmessage/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Message content" ]'JavaScript example POST:
body: '[ 1, "Message content" ]'
fetch("https://engine.tygron.com/api/session/event/editorchatmessage/add/", options)
