Api session event editor chatchannel set instructions
API Endpoint: editorchatchannel/set_instructions.
Description: Set Instructions
| 0 | REQUIRED | (CHAT_CHANNEL Integer ID or multiple values in array [1, 2, 3]) | Chat Channel | |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/set_instructions/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text 1" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/set_instructions/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]'JavaScript example POST:
body: '[ 1, "Text 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorchatchannel/set_instructions/", options)
