Api session event editor chatchannel remove
Revision as of 14:59, 20 April 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: editorchatchannel/remove. Description: Remove existing Chat Channel {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(CHAT_CHANNEL Integer ID or multiple values in array [1, 2, 3]) |Chat Channel | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Boolean (True when at least one item was removed) |- |300-600 |Codes Overview |} ===Example POST=== Curl example POST: <syntaxhighlight lang="...")
0 REQUIRED (CHAT_CHANNEL Integer ID or multiple values in array [1, 2, 3]) Chat Channel
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorchatchannel/remove/", options)
