Api session event editor chatchannel add
Revision as of 14:59, 20 April 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: editorchatchannel/add. Description: Add new Chat Channel {|class=wikitable !Name !Importance !Type !Description !Values |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer (ChatChannel ID) |- |300-600 |Codes Overview |} ===Example POST=== Curl example POST: <syntaxhighlight lang="text" copy>curl 'https://engine.tygron.com/api/session/event/editorchatchannel/add/' -H 'Content-Type: application/json' -H 'Authorizatio...")
200 Integer (ChatChannel ID)
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ ]'
JavaScript example POST:
 body: '[ ]'
fetch("https://engine.tygron.com/api/session/event/editorchatchannel/add/", options)
