Api session items functions
Revision as of 13:28, 20 April 2026 by Frank@tygron.nl (talk | contribs)
Api session items Function Endpoints.
Default Query:
https://engine.tygron.com/api/session/items/functions/?f=JSON&token=API_TOKEN
Example Response:
  "attributes" : {
    "DISTURBANCE_DISTANCE_M" : [ 0.0 ],
    "OTHER_CONSTRUCTION_COST_M2" : [ 4000.0 ],
    "BOWEN_RATIO" : [ 3.0 ],
    "NUM_PEDESTRIANS" : [ 0.0 ],
    "OTHER_SELL_PRICE_M2" : [ 5000.0 ],
    "OTHER_HEAT_FLOW_M2_CHANGE_PER_YEAR" : [ 0.0 ],
    "SLANTING_ROOF_HEIGHT" : [ 0.0 ],
    "ZONING_PERMIT_REQUIRED" : [ 0.0 ],
    "NUM_CARS" : [ 0.0 ],
    "GROUND_COLOR" : [ -4808597.0 ],
    "ALIGN_ELEVATION" : [ 2.0 ],
    "NUM_BICYCLES" : [ 0.0 ],
    "OTHER_PARKING_LOTS_PER_M2" : [ 0.0 ],
    "ROOF_COLOR" : [ -4808597.0 ],
    "SEWERED" : [ 0.0 ],
    "OTHER_HEAT_POWER_TO_FLOW_MULTIPLIER" : [ 0.0 ],
    "DRAINAGE" : [ 0.0 ],
    "JAM_FACTOR_CARS" : [ 0.0 ],
    "TRAFFIC_LANES" : [ 0.0 ],
    "LIVABILITY_EFFECT" : [ 0.0 ],
    "WATER_MANNING" : [ 0.025 ],
    "WATER_STORAGE_M2" : [ 0.0 ],
    "MONUMENTAL" : [ 0.0 ],
    "NUM_TRUCKS" : [ 0.0 ],
    "OTHER_BUYOUT_COST_M2" : [ 4000.0 ],
    "NUM_AIRPLANES" : [ 0.0 ],
    "GROUND_INFILTRATION_MD" : [ 0.0 ],
    "NUM_BUSES" : [ 0.0 ],
    "OTHER_UNIT_SIZE_M2" : [ 1.0 ],
    "NUM_VANS" : [ 0.0 ],
    "SOLID" : [ 0.0 ],
    "JAM_FACTOR_VANS" : [ 0.0 ],
    "HEIGHT_OFFSET_M" : [ 0.0 ],
    "WATER_TRANSPIRATION_FACTOR" : [ 0.0 ],
    "CRITICAL_INFRASTRUCTURE" : [ 1.0 ],
    "ROOT_DEPTH_M" : [ 0.0 ],
    "TRAFFIC_NOISE_SIGMA" : [ 0.0 ],
    "TRAFFIC_SPEED" : [ 0.0 ],
    "HEAT_EFFECT" : [ -6.0 ],
    "VEGETATION_FRACTION" : [ 0.0 ],
    "OTHER_HEAT_FLOW_M2_START_YEAR" : [ 0.0 ],
    "OTHER_DEMOLISH_COST_M2" : [ 250.0 ],
    "OTHER_HEAT_FLOW_M2_START_VALUE" : [ 0.0 ],
    "WATER_MICRORELIEF_M" : [ 0.0 ],
    "NUM_SHIPS" : [ 0.0 ],
    "MAX_FLOORS" : [ 1.0 ],
    "OTHER_CATEGORY_WEIGHT" : [ 1.0 ],
    "JAM_FACTOR_TRUCKS" : [ 0.0 ],
    "NUM_TRAINS" : [ 0.0 ],
    "OTHER_PARKING_LOTS_DEMAND_PER_M2" : [ 0.0 ],
    "DISTANCE_ZONE_M" : [ 0.0 ],
    "TRAFFIC_NOISE_TAU" : [ 0.0 ],
    "FOLIAGE_CROWN_FACTOR" : [ 0.0 ],
    "BASEMENT_COLOR" : [ -1.1776948E7 ],
    "DEFAULT_FLOORS" : [ 1.0 ],
    "EXTRA_COLOR" : [ -4808597.0 ],
    "SOLAR_PANELS" : [ 0.0 ],
    "TOP_COLOR" : [ -4808597.0 ],
    "JAM_FACTOR_BUSES" : [ 0.0 ],
    "NUM_TRAMS" : [ 0.0 ],
    "BASEMENT_HEIGHT_M" : [ 0.0 ],
    "PIPES_PERMITTED" : [ 0.0 ],
    "FLOOR_HEIGHT_M" : [ 0.0 ],
    "TERRAIN_MIX" : [ 0.8 ],
    "MIN_FLOORS" : [ 1.0 ],
    "SAFETY_DISTANCE_M" : [ 0.0 ]
  "categories" : [ "OTHER" ],
  "constructionPeriods" : [ ],
  "decals" : null,
  "defaults" : [ ],
  "description" : "",
  "dimension" : -1,
  "id" : 0,
  "imageName" : "braak.png",
  "modelSetID" : 1,
  "name" : "Vacant Lot",
  "placementType" : "LAND",
  "regions" : [ "NORTHWESTERN_EUROPE" ],
  "textures" : {
    "ROOF" : "sand"
  "version" : 130
  "attributes" : {
    "SLANTING_ROOF_HEIGHT" : [ 2.2 ],
    "ZONING_PERMIT_REQUIRED" : [ 1.0 ],
    "GROUND_COLOR" : [ -1.0197916E7 ],
    "ALIGN_ELEVATION" : [ 0.0 ],
    "ROOF_COLOR" : [ -1.0599374E7 ],
    "SEWERED" : [ 1.0 ],
    "LIVABILITY_EFFECT" : [ -5.0 ],
    "WATER_MANNING" : [ 0.013 ],
    "SOCIAL_UNIT_SIZE_M2" : [ 80.0 ],
    "SOCIAL_PARKING_LOTS_PER_M2" : [ 0.0 ],
    "SOLID" : [ 1.0 ],
    "SOCIAL_CONSTRUCTION_COST_M2" : [ 2000.0 ],
    "HEAT_EFFECT" : [ 5.0 ],
    "SOCIAL_SELL_PRICE_M2" : [ 3000.0 ],
    "SOCIAL_CATEGORY_WEIGHT" : [ 1.0 ],
    "SOCIAL_HEAT_FLOW_M2_CHANGE_PER_YEAR" : [ -1.26E-4 ],
    "MAX_FLOORS" : [ 3.0 ],
    "SOCIAL_HEAT_FLOW_M2_START_VALUE" : [ -0.315264 ],
    "SOCIAL_BUYOUT_COST_M2" : [ 2400.0 ],
    "SOCIAL_PARKING_LOTS_DEMAND_PER_M2" : [ 0.029999999329447746 ],
    "DEFAULT_FLOORS" : [ 2.0 ],
    "EXTRA_COLOR" : [ -1.0197916E7 ],
    "SOCIAL_HEAT_POWER_TO_FLOW_MULTIPLIER" : [ 4.86 ],
    "TOP_COLOR" : [ -1.0197916E7 ],
    "SOCIAL_HEAT_FLOW_M2_START_YEAR" : [ 1900.0 ],
    "BASEMENT_HEIGHT_M" : [ 2.0 ],
    "FLOOR_HEIGHT_M" : [ 3.2 ],
    "SOCIAL_DEMOLISH_COST_M2" : [ 150.0 ],
  "categories" : [ "SOCIAL" ],
  "constructionPeriods" : [ "POST_WAR" ],
  "decals" : {
    "ROOF" : [ ],
    "GROUND" : [ 10.0, 1.0, 1.0, 1.98, 2.4, 0.0, 0.0, 3.3, 1.98, 4.3, 0.81, 0.0, 6.8, 1.98, 7.8, 0.81, 0.0, 8.5, 1.98, 9.5, 0.81 ],
    "EXTRA" : [ 10.0, 0.0, 1.0, 1.98, 2.0, 0.84, 0.0, 2.7, 1.98, 3.7, 0.84, 0.0, 8.2, 1.98, 9.2, 0.84 ],
    "TOP" : [ 10.0, 0.0, 1.0, 1.74, 2.0, 0.6, 0.0, 4.5, 1.74, 5.5, 0.6, 0.0, 6.2, 1.74, 7.2, 0.6 ]
  "defaults" : [ ],
  "description" : "",
  "dimension" : -1,
  "id" : 1,
  "imageName" : "huisje7.png",
  "modelSetID" : 2,
  "name" : "Mid-Century affordable housing",
  "textures" : {
    "ROOF" : "pane",
    "GROUND" : "bricks",
    "EXTRA" : "bricks",
    "TOP" : "bricks"
  "version" : 131
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/functions/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/functions/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/functions/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/functions/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/functions/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/functions/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/functions/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/functions/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/functions/?f=ZIPSMILE&token=API_TOKEN
Api Model BaseFunction
API Model description of BaseFunction
Name Type Description
attributes Map<String,double[]>
categories Category[]
constructionPeriods ConstructionPeriod[]
decals Map<FaceType,float[]>
defaults Type[]
description String
dimension int
id int
imageName String
modelSetID int Model Set ID
name String
placementType PlacementType
regions Region[]
textures Map<FaceType,String>
version int
Api Model DuplicateFunction
API Model description of DuplicateFunction
id int
orginalFunctionID int Function ID
version int
Api Model Function
API Model description of Function
id int
version int
