Api session items clientwords
Revision as of 12:38, 20 April 2026 by Frank@tygron.nl (talk | contribs)
Api session items Client Words Endpoints.
Default Query:
https://engine.tygron.com/api/session/items/clientwords/?f=JSON&token=API_TOKEN
Example Response:
  "id" : 0,
  "translation" : "Above ground: %s",
  "version" : 1
  "id" : 1,
  "translation" : "Above average",
  "version" : 2
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/clientwords/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/clientwords/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/clientwords/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/clientwords/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/clientwords/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/clientwords/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/clientwords/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/clientwords/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/clientwords/?f=ZIPSMILE&token=API_TOKEN
Api Model ClientTerms
API Enumeration description of ClientTerms
Name Description
ABOVE
ABOVE_AVERAGE
ACTION_LOG_APPLIED
ACTION_LOG_BUILD
ACTION_LOG_DEMOLISH
ACTION_LOG_FAILED
ACTION_LOG_LEVEE
ACTION_LOG_LOWER_LAND
ACTION_LOG_MEASURE_BUILD
ACTION_LOG_MEASURE_CANCEL
ACTION_LOG_RAISE_LAND
ACTION_LOG_RESTORED_LAND
ACTION_LOG_REVERT
ACTION_LOG_UPGRADE
ACTIVE_BREACH
ADD
ADDED
ALIGN_ELEVATION
ANDWORD
ANSWER
APPLY
AVERAGE
BAD
BASE
BASEMENTCOLOR
BELOW_AVERAGE
BLOCK_MEASUREMENT
BLOCK_SELECTION
BORDER
BOWEN_RATIO
BREACH_AREA
BREACH_INPUT_AREA
BREACH_LEVEL_AREA
BUDGET
BUDGET_AMOUNT
BUDGET_BALANCE
BUDGET_ITEM
BUDGET_PERSONAL_BUDGET_ABRV
BUDGET_PERSONAL_EXPENSES
BUDGET_PERSONAL_INCOME
BUILD
BUILDING_HEIGHT
BUILDING_NAME
BUSY
BUY
BUY_FROM
BUY_LAND
BUY_PRICE
BUY_SELL_LAND_CALCULATION_EXPL
BUY_SELL_LAND_MAXIMUM_AMOUNT
BUY_SELL_LAND_MINIMUM_AMOUNT
BUY_SELL_NO_VALID_BUYERS
CALCULATING
CAMERA_STYLE
CANCEL
CATEGORY_INFORMATION_OVER_BUDGET
CATEGORY_PANEL_SELECTION
CATEGORY_WEIGHT
CHANGED
CHOOSE_SELECTION
CIRCLE_SELECTION
CLICK_ZOOM
CLOSE
CLOSEBY
CLOSER
CONFIRM
CONNECT
CONSTRUCTION_COST
CONSTRUCTIONS
CONTINUE
COOL
COST_BUYOUT
COST_CONSTRUCTION
COST_CONTRIBUTION
COST_DEFAULT
COST_DEMOLISH
COST_MAINTENANCE
COST_RESERVED_CONSTRUCTION
COST_RESERVED_DEMOLISH
COST_RESERVED_UPGRADE
COST_UPGRADE
COSTS
CRICTICAL
CRITERIA_BUILDING
CRITERIA_BUILT_TERRAIN
CRITERIA_CITY_MAP
CRITERIA_DEMOLISHABLE
CRITERIA_DISTANCE_TERRAIN_TYPES
CRITERIA_EMPTY
CRITERIA_EMPTY_FOR_LEVEE
CRITERIA_FUNCTION_CATEGORY
CRITERIA_INCORRECT_PLACEMENT
CRITERIA_MEASURE_BUILDING_TERRAIN_TYPE
CRITERIA_MEASURE_PRESENT
CRITERIA_MEASURE_SPATIAL
CRITERIA_MEASURE_SPATIAL_DEMOLISH
CRITERIA_MULTI_FUCTION
CRITERIA_NEIGHBORHOOD
CRITERIA_NEIGHBORHOOD_REMOVE
CRITERIA_ONLY_LAND
CRITERIA_ONLY_WATER
CRITERIA_OUTSIDE_SELECTION
CRITERIA_OWNED
CRITERIA_OWNED_BY_YOU
CRITERIA_PIPE_FLOWGROUP
CRITERIA_PIPE_FLOWGROUP_REMOVE
CRITERIA_PLAN_AREA
CRITERIA_PLOT
CRITERIA_READY
CRITERIA_RESERVED
CRITERIA_SINGLE
CRITERIA_TERRAIN_TYPE
CRITERIA_UPGRADE
CRITERIA_VACANT
CRITERIA_ZONE
CRITERIA_ZONE_REMOVE
CRITICAL_INFRASTRUCTURE
CROSS_MEASUREMENT
CULVERT
CURRENT
DATE
DECREASE
DEFAULT_BASEMENT_HEIGHT
DEFAULT_FLOOR_HEIGHT
DEFAULT_FLOORS
DEMAND
DEMOLISH
DESCRIPTION
DETAIL_BUYOUT_COST
DETAIL_DEMOLISH_COST
DETAIL_PARKING_SPACES
DETAIL_PARKING_SPACES_DEMAND
DETAIL_SELL_PRICE
DIFFERENCE_OVERLAY
DISCONNECT
DISPLAY
DISTANCE
DISTANCE_ZONE
DISTURBANCE_DISTANCE
DRAINAGE
DRAINAGE_AREA
DRAINAGE_OVERFLOW
ENVIRONMENT_EFFECT
EQUAL
EXCEPTION
EXPLANATION
EXPORT
EXTRACOLOR
FAR
FAST
FEEDBACK_PROCESSING
FINANCE
FLOOR_SPACE
FLOORS
FOLIAGE_CROWN_FACTOR
FUNCTION_CATEGORY_AGRICULTURE
FUNCTION_CATEGORY_BRIDGE
FUNCTION_CATEGORY_EDUCATION
FUNCTION_CATEGORY_GARDEN
FUNCTION_CATEGORY_HEALTHCARE
FUNCTION_CATEGORY_INDUSTRY
FUNCTION_CATEGORY_INTERSECTION
FUNCTION_CATEGORY_LEISURE
FUNCTION_CATEGORY_LUXE
FUNCTION_CATEGORY_NATURE
FUNCTION_CATEGORY_NORMAL
FUNCTION_CATEGORY_OFFICES
FUNCTION_CATEGORY_OTHER
FUNCTION_CATEGORY_PARK
FUNCTION_CATEGORY_PAVED_AREA
FUNCTION_CATEGORY_ROAD
FUNCTION_CATEGORY_SENIOR
FUNCTION_CATEGORY_SHOPPING
FUNCTION_CATEGORY_SOCIAL
FUNCTION_CATEGORY_STUDENT
FUNCTION_CATEGORY_UNDERGROUND
FUNCTION_CATEGORY_WATER
FUNCTION_FLOOR_AREA
FUNCTION_GROUND_INFILTRATION
FUNCTION_HEAT_INFLUENCE
FUNCTION_INCOME
FUNCTION_PARKING
FUNCTION_PHYSICAL
FUNCTION_ROOT_DEPTH
FUNCTION_UNITS
FUNCTION_WATER_TRANSPIRATION
FUNCTION_WATER_MANNING
FUNCTION_WATER_MICRORELIEF
FUNCTION_WATER_STORAGE
FURTHER
GOOD
GOTO_2D
GOTO_2D_TIP
GOTO_3D
GOTO_3D_TIP
GRAPH_ABSOLUTE
GRAPH_FIT
GREEN
GRID_CELL
GRID_TOOL_TIP
GROUND_HEIGHT
GROUNDCOLOR
HEAT_FLOW_M2_CHANGE_PER_YEAR
HEAT_FLOW_M2_START_VALUE
HEAT_FLOW_M2_START_YEAR
HEAT_POWER_TO_FLOW_MULTIPLIER
HEIGHT_OFFSET
HELLO_WORLD
HIDE_DIFFERENCE
HIDE_DIFFERENCE_INFO
HIGH
HOUSES
HOUSING
HOVER_INFORMATION_SCENARIO
IMPROVED
IN_SHADOW
INACTIVE_INPUT_AREA
INCOME_DEFAULT
INCOME_INITIAL
INCOME_SALES
INCREASE
INDEXATION
INFO
INFO_CURRENT_PLANNING
INFO_MAQUETTE_PLANNING
INLET
INUNDATED_AREA
JAM
JAM_FACTOR_BUSES
JAM_FACTOR_CARS
JAM_FACTOR_TRUCKS
JAM_FACTOR_VANS
LAND
LANDSCAPE
LEVEE
LEVEE_HEIGHT
LEVEE_WIDTH
LEVEL
LINE_MEASUREMENT
LINE_SELECTION
LOSS
LOW
MAQUETTE
MAX_FLOORS
MEASURE
MEASURE_CONSTRUCTED_BY
MEASUREMENT_ADD
MEASUREMENT_COMBO
MEASUREMENT_EXPLAIN
MEASUREMENT_OBJECT
MEASUREMENT_REMOVE
MEASUREMENT_SELECT
MENU_IN_VIEWPORT_CONFIRM
MENU_IN_VIEWPORT_EXIT
MENU_IN_VIEWPORT_SAVE
MENU_IN_VIEWPORT_SETTINGS
MENU_IN_VIEWPORT_TITLE
MIN_FLOORS
MINIMIZE
MONEY_TRANSFER
MONEY_TRANSFER_DESCRIPTION
MONEY_TRANSFER_TO
MONEY_TRANSFER_TO_OTHER_PLAYER
MONTHS
MONUMENTAL
MOVE_FIRST_PERSON
MUCH_CLOSER
MUCH_FURTHER
NAME
NEARBY
NEIGHBORHOODS
NETWORK_FAIL
NO
NO2_CONCENTRATION
NO2_EMISSION
NO2_TREEFACTOR
NO2_TREES
NOISE_DB
NOISE_EMISSION
NORMAL
NOT_CONNECTED
NOT_ENOUGHT_MONEY
NOT_IN_SHADOW
NOTHING_SET
NOX_EMISSION
NUM_AIRPLANES
NUM_BICYCLES
NUM_BUSES
NUM_CARS
NUM_PEDESTRIANS
NUM_SHIPS
NUM_TRAINS
NUM_TRAMS
NUM_TRUCKS
NUM_VANS
OK
OPEN
OTHER
OVERHEATED
OVERLAY_CHANGE
PAN_CAMERA_DOWN
PAN_CAMERA_UP
PARTIAL_SKY_VIEW
PERMITTER
PIPES_PERMITTED
PLANNING_CURRENT
PLANNING_MAQUETTE
POINT_MEASUREMENT
POLDER_WATER
POLYGON_PICK_SELECTION
PRICE
PRIORITY
PROCESSING
PROGRESS
PUMP
QUIET
RELATIVE
RELEASED_FROM_SESSION
REMOVE
REMOVED
RENAME
RESET
RESPOND
RESPONSE
RESTORE
RESULT
REVOKE
ROOFCOLOR
ROTATE_CAMERA
SAFETY_DISTANCE
SAVE
SAVED
SCENARIO
SCORE
SEARCH_FOR_ADDRESS
SEARCH_TIP
SELECT_OVERLAY
SELECTED
SELECTION_OK
SELECTION_ACTIVATED_AREAS
SELL
SELL_LAND
SELL_PRICE
SELL_TO
SEND
SESSION
SET
SETTINGS_ADVANCED_BUTTON
SETTINGS_ANTI_ALIASING
SETTINGS_BLOOM
SETTINGS_CARTOON
SETTINGS_CUSTOM_TITLE
SETTINGS_DISPLAY_TITLE
SETTINGS_DOF
SETTINGS_DRAW_DISTANCE
SETTINGS_EFFECT_TITLE
SETTINGS_ENVIRONMENT_TITLE
SETTINGS_FULL
SETTINGS_HIGH
SETTINGS_LOW
SETTINGS_NORMAL
SETTINGS_OFF
SETTINGS_ON
SETTINGS_PRESET_TITLE
SETTINGS_RECOMMENDED
SETTINGS_SHADOW
SETTINGS_SSAO
SETTINGS_SUN_SCATTER
SETTINGS_TEXTURE_QUALITY
SETTINGS_TEXTURE_TITLE
SETTINGS_TITLE
SETTINGS_ULTRA
SETTINGS_WATER
SEWER_AREA
SEWER_OUTLET
SHORELINE
SHOW
SHOW_ACTION_LOGS
SHOW_DIFFERENCE
SHOW_DIFFERENCE_INFO
SHOW_OVERLAY
SLANTING_ROOF_HEIGHT
SLIGHT_DECREASE
SLIGHT_INCREASE
SLIGHTLY_IMPROVED
SLIGHTLY_WORSE
SOCIAL
SOLAR_PANELS
SOLID
SOURCE
STAKEHOLDER
STAKEHOLDER_INDICATOR_SCORE
STAKEHOLDER_INDICATOR_EXACT
STAKEHOLDERS
STATE_CONSTRUCTING
STATE_CONSTRUCTION_APPROVED
STATE_CONSTRUCTION_DENIED
STATE_DEMOLISH_APPROVED
STATE_DEMOLISH_DENIED
STATE_DEMOLISH_FINISHED
STATE_DEMOLISHING
STATE_NOTHING
STATE_PENDING_CONSTRUCTION
STATE_PENDING_DEMOLISHING
STATE_PENDING_UPGRADE
STATE_READY
STATE_REQUEST_CONSTRUCTION_APPROVAL
STATE_REQUEST_DEMOLISH_APPROVAL
STATE_REQUEST_PLOT_APPROVAL
STATE_REQUEST_ZONING_APPROVAL
STATE_WAITING_FOR_CONSTRUCTION_DATE
STATE_WAITING_FOR_DEMOLISH_DATE
SUBSIDY
SUBSIDY_GRANT
SUBSIDY_GRANTED
SUBSIDY_MINIMUM_AMOUNT
SUBSIDY_NOT_GRANTED
SUBSIDY_NOT_VALID_NUMBER
SUM
SUPPLY
SURFACE
SWITCH_PLAYER
TALUD_ANGLE
TERRAIN_MIX
TILE_HEAT_EFFECT_UNIT
TILE_MEASURE
TILE_OUTSIDE_PLAN_AREA
TILE_OWNER
TILE_TOTAL_STORAGE
TILE_WATER_STORAGE_PER_M2
TIME
TIMEFRAME_FAST_FORWARD
TIMEFRAME_ID
TIMEFRAME_MIN
TIMEFRAME_PAUSE
TIMEFRAME_PLAY
TIMEFRAME_PLUS
TIMEFRAME_REWIND
TIMEFRAME_TIMESTAMP
TOPCOLOR
TOTAL
TRAFFIC_LANES
TRAFFIC_NOISE_SIGMA
TRAFFIC_NOISE_TAU
TRAFFIC_SPEED
UNDERGROUND
UNDERGROUND_INLET
UNDERGROUND_MODE
UNIT_FLOORSPACE
UPGRADE
VACANT
WATER_AREA
WATER_LEVEL
WATER_STORAGE
WEIR
WORSE
WRITE
XRAY
YEAR
YEAR_OF_CONSTRUCTION
YES
ZONE
ZONE_ALLOWED_CATEGORIES
ZONE_PLAN_CHANGE
ZONING_PERMIT_REQUIRED
ZONINGPLAN
Api Model ClientWord
API Model description of ClientWord
Name Type Description
id int
translation String
version int
