Api session event editor zoning set parent
Revision as of 13:42, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorzoning/set_parent.
Description: Set Parent
0 REQUIRED (ZONE Integer ID) Zone
1 REQUIRED (Integer number) Integer
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorzoning/set_parent/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorzoning/set_parent/", options)
