Api session event editor zoning remove
API Endpoint: editorzoning/remove.
Description: Remove existing Zoning
| 0 | REQUIRED | (ZONE Integer ID or multiple values in array [1, 2, 3]) | Zone | |
| 1 | REQUIRED | (true, false) | Remove Children | true or false |
| 200 | Boolean (True when at least one item was removed) |
curl 'https://engine.tygron.com/api/session/event/editorzoning/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorzoning/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], false ]'JavaScript example POST:
body: '[ 1, false ]'
fetch("https://engine.tygron.com/api/session/event/editorzoning/remove/", options)
