Api session event editor trigger set timing
API Endpoint: editortrigger/set_timing.
Description: Set Timing
| 0 | REQUIRED | (TRIGGER Integer ID or multiple values in array [1, 2, 3]) | Trigger | |
| 1 | REQUIRED | (Timing or multiple values in array [a, b, c]) | Timing[] |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editortrigger/set_timing/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "BEFORE" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editortrigger/set_timing/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "BEFORE", "AFTER", "AFTER" ] ]'JavaScript example POST:
body: '[ 1, "BEFORE" ]'
fetch("https://engine.tygron.com/api/session/event/editortrigger/set_timing/", options)
