Api session event editor source set description
API Endpoint: editorsource/set_description.
Description: Set Description
| 0 | REQUIRED | (SOURCE Integer ID) | Source | |
| 1 | REQUIRED | (String) | String |
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editorsource/set_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text" ]'JavaScript example POST:
body: '[ 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorsource/set_description/", options)
