Api session event editor source add file
API Endpoint: editorsource/add_file.
Description: Add File
| 0 | REQUIRED | (String) | String | |
| 1 | REQUIRED | (String) | String |
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editorsource/add_file/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", "Text" ]'JavaScript example POST:
body: '[ "Text", "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorsource/add_file/", options)
