Api session event editor source set name
API Endpoint: editorsource/set_name.
Description: Set new name of existing Source
| 0 | REQUIRED | (SOURCE Integer ID or multiple values in array [1, 2, 3]) | Source | |
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editorsource/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text 1" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorsource/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]'JavaScript example POST:
body: '[ 1, "Text 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorsource/set_name/", options)
