Api session event editor sound set loop
API Endpoint: editorsound/set_loop.
Description: Set Loop
| 0 | REQUIRED | (SOUND Integer ID) | Sound | |
| 1 | REQUIRED | (true, false) | Boolean | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorsound/set_loop/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false ]'JavaScript example POST:
body: '[ 1, false ]'
fetch("https://engine.tygron.com/api/session/event/editorsound/set_loop/", options)
