Api session event editor netsetting set owner
API Endpoint: editornetsetting/set_owner.
Description: Set Owner
| 0 | REQUIRED | (Enumeration) | NetType | ELECTRICITY, GAS, HEAT, INTERNET or SEWER |
| 1 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetsetting/set_owner/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "ELECTRICITY", 1 ]'JavaScript example POST:
body: '[ "ELECTRICITY", 1 ]'
fetch("https://engine.tygron.com/api/session/event/editornetsetting/set_owner/", options)
