Api session event editor netcluster set owner
API Endpoint: editornetcluster/set_owner.
Description: Set Owner
| 0 | REQUIRED | (NET_CLUSTER Integer ID) | Net Cluster | |
| 1 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetcluster/set_owner/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editornetcluster/set_owner/", options)
