Api session event editor netcluster set fraction connected
Revision as of 13:37, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editornetcluster/set_fraction_connected.
Description: Set Fraction Connected
0 REQUIRED (NET_CLUSTER Integer ID) Net Cluster
1 OPTIONAL (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetcluster/set_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "" ]'
JavaScript example POST:
 body: '[ 1, "" ]'
fetch("https://engine.tygron.com/api/session/event/editornetcluster/set_fraction_connected/", options)
