Api session event editor netcluster remove
Revision as of 13:36, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editornetcluster/remove.
Description: Remove existing Net Cluster
0 REQUIRED (NET_CLUSTER Integer ID or multiple values in array [1, 2, 3]) Net Cluster
curl 'https://engine.tygron.com/api/session/event/editornetcluster/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetcluster/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editornetcluster/remove/", options)
