Api session event editor measurement import
API Endpoint: editormeasurement/import.
Description: Import multiple Measurement
| 0 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | Measurement | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Measurement Names | |
| 2 | REQUIRED | (OVERLAY Integer ID or multiple values in array [1, 2, 3]) | Overlay | |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editormeasurement/import/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
"type" : "GeometryCollection",
"geometries" : [ {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, "Measurement Name 1", 1, "" ]
'Curl example multi item POST:
"geometries" : [ {
"coordinates" : [ [ [ [ 658646.762, 6799451.896 ], [ 658646.762, 6799461.896 ], [ 658656.762, 6799461.896 ], [ 658656.762, 6799451.896 ], [ 658646.762, 6799451.896 ] ] ] ]
"coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
}, [ "Measurement Name 1", "Measurement Name 2", "Measurement Name 3" ], [ 1, 2, 3 ], "" ]
'JavaScript example POST:
body: '[ { "type" : "GeometryCollection", "geometries" : [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ] } ]}, "Measurement Name 1", 1, "" ]'
fetch("https://engine.tygron.com/api/session/event/editormeasurement/import/?crs=3857", options)
