Api session event editor measure set requires confirmation
Revision as of 13:36, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editormeasure/set_requires_confirmation.
Description: Set whether the Measure should be confirmed by other Stakeholder.
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (true, false) Confirmation Required Boolean true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_requires_confirmation/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false ]'
JavaScript example POST:
 body: '[ 1, false ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_requires_confirmation/", options)
